Colloquia Abstracts
Understanding Active Sites and
Activation Processes via the Interaction of Organometallics with Surfaces:
A Combined Spectroscopic-Computational Approach
Professor Susannah L. Scott
Department of Chemical Engineering
Department of Chemistry and Biochemistry
University of California, Santa Barbara
Depositing organometallic complexes on solid supports is a powerful way to
create catalysts with uniform active sites. These catalysts have the potential
to be more active and more selective than conventional heterogeneous catalysts,
at the cost of more difficult synthesis and handling. These hybrid materials
also offer the prospect of being able to probe reaction mechanisms on their
surfaces using the tools of molecular chemistry. One of the most intriguing
questions in heterogeneous catalysis is the mechanism of spontaneous activation
of supported metal oxides. Catalysts such as Cr/SiO2 and Re/Al2O3
generate the supported metal alkyls and alkylidenes that induce polymerization
and metathesis of olefins without any added activator, via direct reaction with
the olefin substrate, and they can be reactivated simply by removing accumulated
catalyst poisons (e.g., by calcination). The first step in using a molecular
complex as a precursor to one of these active sites is to understand its
interaction with the surface. We have recently shown how these reactions inform
us about the distribution of grafting sites, and thereby the interactions
between active sites. For example, silica treated at an elevated temperature
(e.g., 800 °C) has a low surface hydroxyl density, but this does not mean that
the average interhydroxyl distance is very large, or that immobilized
organometallic complexes are "isolated". The EXAFS of Ga(CH3)3
deposited on such a silica shows unequivocally that the hydroxyl sites are
paired, and that the dimethylgallium(III) fragments are close enough to
interact. A DFT model suggest that this interaction likely occurs via bridging
surface oxygens.
Catalytic Production of Liquid Fuels and Chemicals from Biomass-derived
Oxygenated Hydrocarbons
James A. Dumesic
Department of Chemical and Biological Engineering
University of Wisconsin – Madison
Environmental and political issues created by our dependence on fossil fuels,
such as global warming and national security, combined with diminishing
petroleum resources are causing our society to search for new renewable sources
of energy and chemicals, and an important sustainable source of organic fuels,
chemicals and materials is plant biomass. We present results for aqueous-phase
and vapor-phase reforming of oxygenated hydrocarbons, such as glycerol.
Moreover, we show how gas mixtures of H2 and CO can be produced at
high rates and selectivities from glycerol over platinum-based bi-metallic
catalysts at temperatures (e.g., 500-620 K) that are significantly lower
compared to conventional gasification of biomass, allowing this gasification
step to be coupled effectively with hydrocarbon production by Fischer-Tropsch
synthesis. We will also report an integrated catalytic approach for the
conversion of carbohydrates to specific classes of hydrocarbons for use as
liquid transportation fuels. This approach is based on the integration of two
flow reactors operated in a cascade mode, where the effluent from the first
reactor is fed to the second reactor, and can be tuned either for production of
highly branched hydrocarbons and aromatic compounds in gasoline, or for
production of longer chain, less highly branched hydrocarbons in diesel and jet
fuels. This two-reactor approach provides further processing flexibility because
the effluent stream from the first flow reactor produces a liquid organic stream
containing mono-functional compounds, such as alcohols, ketones, carboxylic
acids, and heterocycles that can also be used to provide reactive intermediates
for the lower-volume, but higher value, fine chemicals and polymers markets.
Finally, we will show how hydroxymethylfurfural (HMF) can be formed in high
yields by dehydration of carbohydrates in a biphasic reactor, and we illustrate
how HMF can subsequently be used to produce liquid transportation fuels, such as
dimethylfuran and alkanes ranging from C8 to C15.
Transport in Molecular Junctions: Thoughts Coherent
and Incoherent
Mark A. Ratner
Chemistry Dept. and Center for Nanotechnology
Northwestern University
Current experimental efforts are clarifying quite beautifully the nature of
charge transport in so-called molecular junctions, in which a single molecule
provides the channel for current flow between two electrodes. The theoretical
modeling of such structures is challenging, because of the uncertainty of
geometry, the nonequilibrium nature of the process, and the variety of available
mechanisms. The talk will center on the formulation of the problem in terms of
non-equilibrium theory, and then on the generalizations needed to make that
simple picture relevant to the real experimental situation. These include
antiresonances, vibronic coupling and its control, structural disorder and
representations for the electronic structure. Comments will be made on the
measurements of inelastic spectra, and the information to be gained from them.
Highly Accurate Force Fields for F-elements
and Their Use in Computational Environmental Chemistry
Aurora Clark
Washington State University
An algorithm has been developed for fitting classical force-fields, based
upon the force matching method. It is interfaced with the electronic structure
codes Gaussian03 and Crystal06 and the molecular dynamics codes DL_POLY, LAMMPS,
and Amber. The quality of force-fields fit solely to the ab-initio PES (rather
than experimental observables) has been examined with an emphasis upon the
fitting of different functional forms with varying accuracy to the local minima
vs. the entire dissociation curve for a given potential. Force-fields have
explicitly been developed for trivalent lanthanide ions, enabling molecular
dynamics simulations of their aqueous behavior and sorption characteristics to
common minerals, and allowing for benchmarking to experimental data.
Defining Hydrogen Quality (for Fuel Vehicles)
and Its Impact on Cost
Dennis Papadias
Chemical Sciences and Engineering Division
Argonne National Laboratory
Significant numbers of hydrogen fueled fuel-cell vehicles are expected to be
deployed within the next several years. To develop the infrastructure to fuel
these vehicles, several hydrogen refueling stations are being demonstrated at a
number of locations in the U. S. and elsewhere. Typically, these stations are
producing hydrogen on-site, either by the steam or autothermal reforming of
natural gas, or by the electrolysis of water. The product hydrogen is further
purified using pressure swing adsorption (PSA). As fuel cell vehicles approach
wide-scale deployment, the issue of the quality of hydrogen dispensed to the
vehicles has become increasingly important. The various factors that must be
considered include the effects of different contaminants on fuel cell
performance and durability, the production and purification of hydrogen to meet
fuel quality guidelines, and the associated costs of providing hydrogen of that
quality to the fuel cell vehicles.
This presentation will focus on our efforts to track contaminant levels
through a near-term commercially promising hydrogen production/purification
pathway for producing fuel cell quality hydrogen. This presentation will report
on a process through which the hydrogen is obtained by steam reforming of
natural gas and the hydrogen is then purified using PSA. By developing a model
for the process, the effect of the operating conditions on the process
efficiency, the level of key contaminants in the product hydrogen, and the cost
of hydrogen have been calculated. The results indicate that at suggested
hydrogen quality specifications, CO would limit the maximum hydrogen recovery
from the PSA under typical design and operating conditions. Lowering the CO
specification is not expected to significantly affect the cost of hydrogen.
Johannes A. Lercher
Lerstuhl fuer Technische Chemie, Technische Univ.
Molecular sieves are key elements of catalysts in hydrocarbon catalysis
helping to lead processes to long-term sustainability. To understand the
elementary steps involved in these conversions is a prerequisite to be able to
design and realize new generations of catalysts. The lecture will outline how
new insight into transport and reaction processes has been used to develop
materials allowing faster transport of molecules to the active sites and how the
local environment of the catalytically active sites can be used to induce new
catalytic chemistry. The roles of the steric control of the acid/active site and
of bifunctionality in these processes will be discussed, analyzing how
transition energies and entropies influence activity and selectivity.
Catalytic Autothermal Reforming of Renewable
Fuels at Millisecond Times
Lanny Schmidt
Department of Chemical Engineering and Materials Science
University of Minnesota
We compare the reforming of different types of biofuels by autothermal
reforming at millisecond contact times to produce synthesis gas, hydrogen, and
chemicals. Fuels examined are alcohols, esters, carbohydrates, biodiesel,
vegetable oil, and solid biomass.
Biofuels generally have higher conversions than fossil fuels because the
hydroxyl and ester linkages in these fuels produce higher sticking coefficients
than for saturated alkanes. Consequently, conversions of all biofuels in these
processes are nearly 100%. Highly oxygenated feedstocks tend to produce mostly
syngas with little olefins or oxygenated products because surface reactions
dominate, and these larger products are formed predominantly by homogeneous
reaction processes after all oxygen is consumed.
Recent results on production of syngas by reactive flash volatilization of
nonvolatile liquids and solids will also be described. We show that, by
impinging cold liquid drops or small solid particles onto the hot catalyst
surface, the process can be operated in steady state with no carbon formation
for many hours. This occurs because, while pyrolysis of vegetable oils and
carbohydrates at low temperatures produces carbon, above ~600oC the equilibrium
shifts to produce syngas rather than solid carbon.
Recent results using fast photography at 1000 frames per second will be shown
that examine the time dependence of solid and liquid particle decomposition and
disappearance. Spatial profiles of temperature and species concentrations within
the working catalyst will also be described.
Robert Schlögl
Fritz-Haber-Institut der Max-Planck-Gesellschaft
Metals have been widely studied by model catalysis for their basic catalytic
functions in oxidation and hydrogenation. The extremely important issue of
selectivity has basically been treated for small molecule hydrogenation. A
critical role was ascribed to carbonaceous species co-adsorbed with the
substrate.
The presentation reviews the role of carbon in controlling the selectivity of
hydrogenation and compares it to the role of oxygen in controlling the oxidation
selectivity of metals. It will be demonstrated that the control of the third
dimension of the catalytic material is a crucial requirement for which several
strategies can be adopted.
Quantum Mechanics in Biology: Using
Spectroscopy to Elucidate Design Principles in Photosynthesis
Greg Engel
The University of Chicago
Life on earth is effectively solar-powered, yet how energy moves through
photosynthetic complexes prior to the biochemical steps of photosynthesis is
still not completely understood. Evidence for a purely quantum mechanical
mechanism of energy transfer in photosynthetic complexes was discovered in the
Fenna-Matthews-Olson (FMO) complex of Chlorobium tepidum in 2007. The quantum
beating phenomenon observed in this complex is now much better understood.
Further, new data indicate that this mechanism is not specific to FMO, but
manifests in reaction centers of purple bacteria and antenna complexes of higher
plants. Having observed such a mechanism in disparate photosynthetic complexes,
we are exploring what the minimal requirements are to support quantum coherence
transfer in a biological environment and how such an environment might be
reproduced synthetically. Emerging details in this story will be presented along
with a preview of upcoming experimental efforts to dissect the details of energy
transfer, the basis for the efficiency of the energy transfer process and
efforts to isolate signals at room temperature.
http://www.nersc.gov/news/science/Engel4.png
Coherent Ultrafast Multidimensional
Spectroscopy of Chromophore Aggregates; from NMR to X-Rays
Shaul Mukamel
Department of Chemistry, University of California, Irvine
The multidimensional techniques which originated with NMR in the 1970s have
been extended over the past 15 years to the optical regime. NMR spectroscopists
have developed principles for the design of pulse sequences that resolve
otherwise congested spectra, enhance selected spectral features and reveal
desired dynamical events. These principles may be extended to the optical
regime.
The response of photosynthetic light harvesting complexes to sequences of
femtosecond optical pulses provides multidimensional snapshots of their
structure and electronic dynamics. Two-dimensional (2D) signals show
characteristic cross-peak patterns which carry information about structures,
fluctuations and the entire pathways of energy and charge transfer. The signals
reveal couplings between chromophores, and quantum coherence signatures of
chromophore entanglement. Coherent quantum pathways and incoherent energy
hopping processes may be disentangled. Pulse shaping coherent control strategies
and specific polarization configurations of the optical fields that make use of
molecular chirality enhance the resolution even further applications to
Fenna-Matthews-Olson (FMO) antenna complex and the PSI complex are presented. 2D
signals also provide unique information about electron correlations.
Future extensions to the attosecond regime using x-ray pulses will be
discussed. Since core excitations are highly localized at selected atoms such
signals can monitor the motions of valence electron wavepackets in real space
with atomic spatial resolution. Common principles underlying coherent
spectroscopy techniques for spins, valence electrons, and core electronic
excitations, spanning frequencies from radiowaves to hard X-rays will be
discussed.
“Coherent Multidimensional Optical Probes for Electronic
Correlations and Exciton Dynamics; from NMR to X-rays”, S. Mukamel, D.
Abramavicius, L. Yang, W.Zhuang, I.V. Schweigert and D. Voronine. Acct.Chem.Res.
(April, 2009).
“Double-quantum Coherence Attosecond X-ray Spectroscopy of
Spatially-separated, spectrally-overlaping core-election transitions,” I.V.
Schweigert and S. Mukamel. Phys. Rev. A. 78, 052509(2008).
“Unraveling coherent dynamic and energy dissipation in
photosynthetic complexes by 2D spectroscopy, D. Abramavicius, D. Voronine and S.
Mukamel, Biophys. J.94, 3613-3619, 2008.
Electron Transfer Dynamics at the
Mineral/Microbe Interface
Kevin M. Rosso
Pacific Northwest National Laboratory, Richland, WA 99352
The chemical behavior of mineral-water and mineral-microbe interfaces is
central to aqueous reactivity in natural waters, soil evolution, atmospheric
chemistry, and is of direct relevance for maintaining the integrity of waste
repositories and remediating environmental pollutants. An important subset of
reactions is the exchange of electron equivalents across these interfaces
associated with natural variation in redox conditions or the activity of
microorganisms at the earth’s near-surface. For example, microbially catalyzed
reductive transformation of Fe(III)-oxides to solubilized Fe(II) by
dissimilatory metal reducing bacteria is a process that can link to and control
transport of redox-active contaminants. Detailed microbiologic study has
revealed the presence of highly efficient biomolecular machinery for interfacial
electron transfer localized on the outer-membranes of these microorganisms.
Multi-heme cytochromes with high heme densities appear optimized for efficient
interfacial electron transfer. Furthermore, some Fe(III)-oxides specifically
utilized by these microorganisms, such as hematite, are natural electrical
semiconductors with the propensity to accept and mobilize electrons in support
of sustained microbiologic respiration. This presentation will center on current
experimental and computational modeling research at PNNL focused on elucidating
molecular-scale mechanisms and kinetics of electron exchange across this
interface. In particular, the fundamental behavior of electrons in the mineral
hematite and at key crystallographic terminations will be discussed.
Single-molecule tunneling spectroscopy of microbial outer-membrane cytochromes
will be compared with computational molecular modeling of cytochrome/hematite
electron transfer. Common aspects of biomolecular and solid-state electron
transfer processes at this environmental interface will be highlighted in terms
of modern electron transfer theory.
Molecular Foundations of Surface Chemistry and Catalytic
Selectivity by Metals
Gabor A. Somorjai
Department of Chemistry and Lawrence Berkeley National Laboratory
University of California, Berkeley
Heterogeneous metal catalysts are nanoparticles that carry out reactions at high
reactant gas pressures or in the liquid phase. Instruments developed in Berkeley
for molecular studies under these conditions are sum frequency generation
vibrational spectroscopy, high pressure scanning tunneling microscopy and
ambient pressure X-ray photoelectron spectroscopy. Model surfaces were used to
study heterogeneous catalytic reactions that permitted to control and monitor
the atomic surface structure, composition and reaction intermediates and
simultaneously measure reaction rates and selectivities. This way precise
quantitative correlations could be obtained between catalytic reaction kinetics
and the molecular factors that control reaction dynamics. Single crystal
surfaces were used at first as model catalysts followed by the use of metal and
bimetallic nanoparticles that were synthesized with precise size and shape using
colloid techniques. Catalytic studies that produce a single molecule (ethylene
hydrogenation, CO oxidation) were redirected to focus on reaction selectivity in
multipath chemical processes. Reactions were found to induce restructuring of
the metal surfaces and mobility of adsorbed molecules. Reaction selectivity and
rates can be altered by changing the nanoparticle size in the 0.8 – 10 nm range
and shape (surface structure). Transition metal catalysts that are nanosize
achieve facile restructuring and rapid change in surface composition under
reaction conditions as their low atom coordination permits rapid bond
rearrangements. Exothermic surface reactions can cause the flow of hot electrons
at oxide metal interfaces and the clustering of metal atoms at the interface,
which dramatically increases the metal oxide interface area. Improvements of
techniques for molecular studies of surfaces that provide better time resolution
and spatial resolution will enhance our ability to study the dynamics of
surfaces, which are key to both activity and selectivity during catalysis. The
control of metal nanoparticle size and shape provides opportunities to achieve
superior reaction selectivity. Combined studies of nanoparticle catalyst
synthesis, characterization and reaction studies will accelerate developments of
this important field of chemical sciences and chemical energy conversion.
Homogenous catalysts are easily tailored to accomplish a wide variety of
reactions including asymmetric transformations. With the current developments in
organometallic chemistry and organic chemistry many catalysts can be synthesized
and due to the advances in high throughput screening techniques their
performance can be evaluated systematically. The understanding of catalyst
performance, deactivation pathways and the mechanisms responsible for their
selectivity is still a challenge.
Emilio Bunel, Director
In the presentation we will illustrate the use of homogenous catalysts as
they relate to:
- The development of catalysts for asymmetric hydroformylation
- Reaction mechanisms for Rh-catalyzed processes involving CO as a
building block
- Catalyst deactivation reactions for hydroformylation of cyanide
containing substrates
- Asymmetric transformations involving monodentate ligands
- Ligand design for biphasic catalysis
