Hydrogen Production Using Nuclear Reactors Offers Energy, Environmental
Benefits
Researchers Jennifer Mawdsley (Chemical
Engineering Division, right), and Bilge Yildiz (Nuclear Engineering
Division, left) prepare to conduct electrochemical tests of a
high-temperature steam electrolysis electrode material. |
Argonne is investigating two approaches to make hydrogen from water for the
"hydrogen economy" using a nuclear reactor as a source of heat and electricity.
There are advantages to both approaches—high-temperature (steam) electrolysis,
and hybrid thermochemical-electrochemical cycles—but there also are challenges
related to chemistry and materials, which Argonne is working to meet.
Argonne's Research: High-Temperature (Steam) Electrolysis
High-temperature electrolysis (HTE), or steam electrolysis, uses electricity
to produce hydrogen from steam, instead of liquid water. High-temperature
electrolysis is more efficient than traditional room-temperature electrolysis
because some of the energy is supplied as heat, which is cheaper than
electricity, and because the electrolysis reaction is more efficient at higher
temperatures.
Argonne is part of a team demonstrating the feasibility of this process.
Argonne’s background in solid oxide fuel cell designs and materials is leading
toward improvements in high-temperature electrolysis efficiency and reductions
in costs. The major source of inefficiency in both solid oxide fuel cells and
solid oxide electrolysis cells is poor electrode performance and durability,
which results in large systems and high materials costs. Argonne is developing
oxygen and hydrogen electrode materials for better hydrogen production
efficiency and materials durability.
Hybrid Thermochemical-Electrochemical Cycles
Recent research indicates strong potential for using thermochemical water
splitting processes to produce hydrogen. Thermochemical cycles are a series of
chemical reactions that convert water to hydrogen and oxygen using catalysts at
high temperatures. These processes offer the potential for high-efficiency
hydrogen production at large-scale production rates, but the technology is
relatively immature.
Argonne is investigating a number of hybrid thermochemical hydrogen
production cycles that produce hydrogen from water using heat and electricity
from a nuclear reactor. One cycle under investigation is an adaptation of
sulfuric acid (H2SO4) synthesis and decomposition
processes, termed the sulfur-iodine cycle. The standard sulfur-iodine cycle
requires temperatures above 850°C for one step in the cycle, the decomposition
of sulfur trioxide (SO3). The other reactions in the cycle can be
performed below 500°C.
Argonne is investigating means to lower the temperature of the SO3
to SO2 reaction to 500-600°C. The benefits of lowering the maximum
operating temperature of the cycle are that it allows the use of a lower
temperature heat source, eliminates the need for expensive high-temperature heat
exchangers, and it mitigates the problems associated with corrosion at higher
temperatures. In Argonne’s approach the maximum temperature is lowered by
electrolyzing SO3 using oxide-ion-conducting electrolysis cells.
Argonne is working to develop improved materials and cell designs to maximize
the efficiency of this step in the hydrogen production cycle for operation at
~500°C.
For more information, contact Jennifer Mawdsley, Chemical Engineering
Division (630-252-4608,
mawdsley@cmt.anl.gov, or
Bilge Yildiz, Nuclear Engineering Division (630-252-1769,
byildiz@anl.gov
Other Nuclear Hydrogen Initiative R&D at Argonne
